Fan goes to maxspeed at startup, computer is laggy
The fan goes to maxspeed sometimes even at startup, so I doubt that its because of heat.
Apart from it being annoyingly noisy it also lags quite significantly.
I chose the setup with the strongest CPU etc and I used to play games at max setings without any problems. I have bootcamp installed, but I have the same lag/fan problems in both modes(win7/OSX), so that cant be the source of the problem.
Any ideas?
Is there a way to test it for hardware-malfunction?
Bu iyi bir soru mu?
Please give us the last four figures of your serial number. Also, has the hard drive been changed?
mayer tarafından
2.8 GHz Core i7 (I7-2600S)
Intro Date: May 3, 2011 Disc Date: October 23, 2012
Order No: BTO/CTO Model No: A1311 (EMC 2428)
Subfamily: Mid-2011 Model ID: iMac12,1
Std RAM: 4 GB Std VRAM: 512 MB
Std Storage: 1 TB (7200 RPM) Std Optical: 8X DL "SuperDrive"
Complete iMac "Core i7" 2.8 21.5-Inch (Mid-2011) Specs
oldturkey03 tarafından
The drive has never been changed.
Albert tarafından
