Ana içeriğe geç
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
laptop keep restarting when using
when working and using my laptop it restart by itself
and loose my work
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
All modern processors has a safety feature that shuts down the computer once the processor reaches a certain temperature, to ensure that the processor is not damaged.
Typically the processor overheats if the air intake vents are blocked - either if you are using the computer on a pillow, blanket etc. which restricts the air flow into the fans or because the fans are blocked by dust.
If you are up for it, I would suggest that you clean the fan. The procedure is not that complicated and can be done by almost anyone :) As an example, you could follow this tutorial: https://www.youtube.com/watch?v=nv8rZYut...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
nazih hudhud sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 178
