Bottom of touchscreen not responding?
I just replaced the screen on my 3Gs and everything went smoothly except now the bottom 3/4" of the touchscreen does not register any touch. The rest of the touchscreen works fine.
Any ideas?
edit: it appears now to work but requires a lot of pressure... again, the rest of the touchscreen is fine.
perhaps the glass is not seated correctly?
Bu iyi bir soru mu?
2 Yorum
Hi evanhaveman, just wondering if you were able to solve the issue. I am having similar issues: after replacing screen, it is not responding right (bottom portion not responding well, can't scroll up and down well, chooses wrong app or alphabet even though the right portion of the touch screen is touched). Others with similar issues were suggested to do a hard reset to recalibrate. Just wondering if you have had any luck with your phone....
amoltakalkar tarafından
the bottom row of my touch screen just stopped responding also. And then I went to a web page & when tried to close window it took NUMEROUS tries before it finally worked. Other than thaat the rest of my apps/screen works except I.m having a harder time getting my lock to open when I swipe it
Gidget tarafından
