Ana içeriğe geç
Nisan 2012'de piyasaya sürülen HTC One X, dört çekirdekli işlemciyle donatılmış ilk HTC telefonudur.
Why is my sim card slot, not reading my sim card?
Sim card slot is not detecting sim card. Sim card does work, tried it in another phone.
Bu iyi bir soru mu?
Puan 135
48 Yorum
Hai all,
I have a Tab named Daawind 7c+Tm .It show a massage ( Sim card not detected) ,and sim card not work in my Tab ,But in the past its was working properly,so Pl hepl me if any know about that.
tarafından
I have a Huawei One A9 handset and a Sim Card issue it has double Sim, I sloted both Sims in and switch on the phone but nothing happen on the network signal. It displayed "No Sim Card"
Can something help me out here??????????????
tarafından
I have a prestigio multipad and i just resetted my phone. Before i could reset i removed my sim .Now i tried putting it in again but its not reading
tarafından
You should try cleaning the spokes on your sim card reader and your sim card. When you put it back in your phone make shour it is nice and snug. If its not snug in there good get a piece of paper and rip a part off and fold it. Put it on your sim card and place it in your phone. If the problem still acours you either have a software problome (not likely) or you have a faulty sim card reader. If you meed a new phone I recamend the blue branded phone on amazon
tarafından
I have a myphone32 i sloted both sims in and switch on the phone but nothing happened on the network signal.It displayed NO SIM CARD
tarafından
43 tane daha yorum göster
Yorum Ekle
22 Cevap
Filtre ölçütü:
Seçilen Çözüm
A simple solution/work around to this issue involves placing a small piece of tape or paper behind your phone's SIM card and sliding it into place as normal, don't force it, it should slide in smoothly with no extra force needed. If done correctly, this may make your SIM card fit more snug into the SIM card tray and enhance the SIM card's connection.
Bu yanıt yardımcı oldu mu?
Puan 59
44 Yorum:
it worked man... with a very small screw driver i pulled up the sim contact ,( actually one of the contact was bent down deu to pressure while cleaning the sim slot)
thanks man, thanks a lot:)
u saved my repair money :)
tarafından
Mr Nyles My sim is not working in my Samsung Galaxy s4, but other sims are working and my sim is working in other mobiles as well. what could be the wrong. I tried with small piece of paper but no use.
tarafından
great job man
its working
tarafından
what to do if the problem is in phone, software or something
tarafından
Hello guys..I am having the xiaomi redmi note 3 and I am able to make calls from it and send messages ..but I can't see the contacts in my sim. How can I make my phone detect the contacts of my sim??
tarafından
39 tane daha yorum göster
Yorum Ekle
Hi,
If you have a message like "Cannot detect SIM card" and this SIM card work well with another phone, then you have a hardware problem. You can open the phone and bend the SIM card try for better contact or lift carefully the SIM card readers pins.
But this operation is not easy.
Regards.
Puan 10
8 Yorum:
Try and Check if Manually Set 2 G or 3 G gives U Full Network Bars.Matter is over.Dont use auto options .fix for 2G only or 3G only separately.Sim will be detected with enough Network.ThanQ.
tarafından
When i insert my sim,my tab says "Sim card inserted,reboot to use" or reboot to i dont remeber wht it says,but "simcard inserted" is wht i remeber,but when i reboot,simcard is not detected?
tarafından
Hey All,
I have the same problem I think I have to go to the mobile hardware to fix isn't it....
tarafından
hello all.
i have some problem ..that is ..my docomo sim doesn't supported in micromax canvace C1 mobile. when i insert the sim no effect in the setting..what can i do for that?
tarafından
It is working in another mobile but it is not working in my mobile what to do now
tarafından
Yorum Ekle
I have a HTC lever and I run on the 4g LTE network and my sim was having trouble staying connected 10 times a day or more.
I searched this site and several others for the solution for this annoying problem.
I solved this problem with 2 layers or transparent tape on the back of the sim card. Be sure to try this if your provider can't help.
Thanks members of ifixit.
Puan 10
6 Yorum:
I have a Lava Iris X5. Sim card was not detected for more than 3 hours and I tried each and every possible methods I had knew... but no use...I put three layers of tape and bent my sim several time gently and inserted it to the slot...I worked fine...thanks
tarafından
Hi my Lenovo tablet is not picking up my sim so I thing it my sim slot that is not working but how can I fix it with going to anybcell phone shop plz help me to fix it fast
tarafından
My phone redmi note 1s do not accept any SIM card
tarafından
He guys when I put my sim in it says sos and searching or no service why?
tarafından
1 tane daha yorum göster
Yorum Ekle
Check if the gold side is dirty
It may be locked
Puan 8
1 Yorum:
sim card is working on my brother's mobile.sounds as though it is because when i accidentaly put the phone'backwards.
makes a continuing noise,but not charging.(have i damaged the mobile?
tarafından
Yorum Ekle
Hi Paresh,
This means that there is some issue with the Sim Slot in your phone, get it checked by service center if under warranty or from a local shop if the warranty is expired.. They will have to replace the Sim slot
Regards
Rohan
Puan 8
1 Yorum:
should it be on the shiny part or other part
tarafından
Yorum Ekle
hi guys, u should try stick 3 layer piece of paper & cut the paper according to same size of the simcard. Put it back to the slot and it should work well.
Puan 4
2 Yorum:
Why my Sim card does not work
tarafından
maybe your sim slot is broken. Send your phone to service centre to change it
tarafından
Yorum Ekle
For me it was required both to ad a tape to back of the sim, clearing the cached data and rebooting. Problem solved. I don't know which of these steps actually solved the problem.
Puan 3
Yorum Ekle
My phone is showing only one slot on display even i inserted both sim in tray but it seems like my phone has only one slot .. please help me ..I am a oppo
Puan 2
1 Yorum:
same with me....if 1 put sim 1 and 2 both...only sim 1 works....if i replace sim 1 with sim 2...only sim 2 works....i don't know what to do
tarafından
Yorum Ekle
Puan 1
2 Yorum:
I used an index card cut to size and inserted it above the SIM card. Worked like a charm. Thanks for the suggestion
tarafından
respected maam my samsung A7 detect sim but not working . show emergency calls only .
tarafından
Yorum Ekle
I have a dual sim card, BLU - studio xl 2. SIM slot 1 doesn´t work (but it worked twice). What can I do? Thanks in advance.
Puan 1
Yorum Ekle
https://www.youtube.com/watch?v=kwsWmHfl...
Puan 1
3 Yorum:
My sim is saying no sim and no signal tuck it phone shop they said it's the sim drive how can I fix it pls
tarafından
Hi guyz, I have a problem with my phone, my phone does not support any simcard in plot 2 till I select airtel card in plot 1, my phone is BRAVO Z11 help me guys
tarafından
I have an XMobile X8 Pro, cleaned a SIM card that was stuck to a friend of mine's shoe, walked off, then later tonight I cleaned it with Isopropryl Alcohol, reinserted it four different ways, and the reader would not recognize it. Any ideas?
tarafından
Yorum Ekle
Dual sim that only detects one line on either slot, when both lines are inserted it doesn't pick any network... Its an android phone. Issue is a week long old
Puan 1
Yorum Ekle
is not working beacause of proxy. and i am using the prepaid SIM in huawei reader.
not dircet reading
Puan 1
1 Yorum:
hi there i cannot used my simcard, i try to the other phone also not function, any one there can help me?
tarafından
Yorum Ekle
i inserted sim then also it is showing no sim
Puan 1
Yorum Ekle
My SIM card was working alright after I took it of the phone it suddenly sti working when I try to insert it back
Puan 1
Yorum Ekle
My sim was working alright but it stoped after I removed it and trying to insert it back again
Puan 1
Yorum Ekle
My phone show sim empty what can I do for this problem yesterday water in my phone
Puan 1
Yorum Ekle
If your sim card not dedect in your phone. At first check your phone is whether 2g, 3g,4g similarly you check your sim. you cannot use 4g sim in 3g phone.
You insert the sim in your phone and restart your phone.
If your problem is not solved you go to store and change your sim card.
Puan 0
2 Yorum:
My lenovo tablets 3 7 its not detected my other card its working only in one card
tarafından
My iPad 3 doesn't read SIM card
tarafından
Yorum Ekle
why won’t my sim card fit in the slot on my android phone
Puan 0
Yorum Ekle
Many phone sim card holders have a switch to detect the card.
The switch s normally closed, it opens when the card is inserted.
The CD signal is on the far right hand side of the holder.
If you cannot get inside the holder, cut this pin from the pcb and it will assume the card is already in it permanently.
Puan 0
1 Yorum:
Hi I can’t get my hubby’s Kyocera rugged flip phone to register the sim - I tried putting tape over it but it still says no service ,any help please?????
tarafından
Yorum Ekle
Hello… pls help me my phone can't accept other sim card network SA
Puan 0
Yorum Ekle
While I was transferring my sim to this and that phone as it was delaying to give some messages, we thought that the phone is not working. While doing so my sim started showing no sim card when i put in other phones. So i bought a new number phone and put the sim in that phone but it is still not working and my sim card is registered in someone else's name who I am unable to contact and the airtel service says they cannot change sim without that person's adhaar card. Now I am on a fix as my number is registered in all important places and I am having problem getting any important messages What to do. Please help. I am in great problem. Please share some of your valuable tips. Thanks and regards.
Puan 0
Yorum Ekle
Yanıtını ekle
Lewis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 76
Her zaman: 584,315
