Ana içeriğe geç
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99 Soru Tümünü görüntüle
intermittent flickering on cinema display
I have a 30" cinema display that intermittently will start flickering lines like crazy.. Here's a video demonstrating the problem:
http://tinyurl.com/nnc8toj
I am wondering if anyone has seen this before, and if it is the power supply? I don't want to spend $200 on a new 150w HD power supply if that's not the problem......
Thanks.
Bu iyi bir soru mu?
Puan 0
3 Yorum
that flickering looks like bad caps
tarafından
Does anyone know where I can find instructions on how to open this model up? It's the 2006 LCD 30" version... Every link I go to on google that looks like it might be instructions turns out to be dead.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I have same problem its not the monitor cable, ive checked this as I have dual monitors and psu's, swapped monitors same flicker on the one powersupply A1097 90w
Update (04/08/2020)
Yes just got a replacement powersupply supply on ebay and works correctly.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
So the power supply was bad then!
tarafından
Yorum Ekle
Have you checked on a different display?
If you see the same flickering on a different display it traces back to your video cables or the CPU/VGC. I'd try that test first.
If this answer is acceptable please remember to return and mark it.
Puan 0
3 Yorum:
Well, this flickering happens with both my macpro and macbook pro.... I can't swap cables with the monitor because it appears the cables are permanently attached (unless I am missing some secret way to unplug them?)
tarafından
What I meant was to plug the computer into a different monitor to ensure that the problem was with the display, not the computer. Having the problem with two different computers pretty much points to your video cables or the display. The only way to be certain you haven't damaged the cable is to replace it. Cheaper and easier than replacing the caps if that is the problem.
tarafından
Does the video cable/connector look worn? Also try a different AC power cord.
tarafından
Yorum Ekle
Yanıtını ekle
patrick3 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 3,047
