upgrade my HDD from 1TB to 2tb
I would like to upgraded my HDD from 1TB to 2tb for Mid -2007 24inch EMC 2134. It is possible?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Yes & no - While the OS can support the larger sized HD. Your system has an older SATA port, SATA I (1.5 Gb/s) most of the larger HD's have a much faster SATA speed SATA III (6.0 Gb/s). So you'll encounter problems if you're not careful. I would recommend you go with a SSHD unit vs a straight HD here as they often can support the older systems. As an example Seagate's SSHD would work here Seagate desktop SSHD's.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 161
