Ana içeriğe geç
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Soru Tümünü görüntüle
Soru Kapandı
No Power, Diag LED #4 briefly lights...How test Pow Sup and MB?
Dead IMAC.....is there a procedure short of replacing the power supply and the logic board?
Once you remove the LCD, you can see the 4 diagnostic LED's on the Logic Board.
When I apply AC power, LED 4 breifly lights up and then goes dark. The Start button does nothing.
Is there a way to test the Power Supply?
How do I know if this is a Logic Board issue?
I bought this with a known issue and no ram and no Hard Drive.....silly me.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You'll need to install some ram to start with and either have a OS installer disk or have a bootable thumb drive/HD to run the system.
OK, so assuming you have the bare minimum required to run the system here. I wound inspect the LVDS cable and the horz. sync cables make sure they are not damaged also check the connectors as well. Your symptom sounds like something is shorted.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 157
