Ana içeriğe geç
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Soru Tümünü görüntüle
Soru Kapandı
Power does not come on
I have followed the instruction to install the dual hard drive kit but after reassembling the power does not come on. How should I troubleshoot this issue?
Update
Gone over the guide as you have suggested and found no disconnected wires or issues. However, you were right, it fixed the issue. Thank you.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Go back over all your connectors - particularly reverse of steps #22, & 16. Many times DIYers "think" or "believe" that connectors are correct but on a second check they find they were not square, snapped in, or that ribbon cable connectors were inserted completely (right side up) and locked in place.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 102
