Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Soru Tümünü görüntüle
Soru Kapandı
Are there any hard drive differences between this and the Mid-2013?
I'm looking to upgrade my Macbook's hard drive to the 940GB version. The site doesn't include the Mid-2014 version in the list of Macbook Pros that it's compatible with. However, the Jetdrive 725 IS compatible with the Mid-2013 version. Are there any differences?http://www.transcend-info.com/apple/jetd...
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
As to what SSD is compatible with the newer '14 model.
Apple has been tweaking the SSD firmware on the M.2 SSD's so far they have three different firmware revs across the MacBook Pro models. It also turns out each rev of firmware is only compatible with a given model so one can't switch what looks like the exact same M.2 module between the different systems. Talk about confusion!
So far we have stayed away from trying to figure this all out. We where hoping Apple (and the other system manufactures) would have stabilized things by now so the SSD's would be standardized like SATA drives as well as be more upgradable and interoperable.
I think your best bet here is to talk with Transcend sales directly and also make sure you can return it if it doesn't work.
Their Web site does not list it as workable. You have a MacBookPro11,2 or MacBookPro11,3 so I would say it likely isn't. Sorry ;-{
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 676
