Ana içeriğe geç
10.1 inçlik Galaxy Tab tabletin üçüncü nesli.
Why did my home button stop working?
Ever since I replaced the charging port and flex ribbon, the home button stopped working. Did I lose or damage a piece? If so, what is/are the piece(s) called to that I can order and replace?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 11
1 Yorum
you just need to reattach the ribbon properly
tarafından
Yorum Ekle
16 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Had the same problem after a battery change
Found that gold ribbon on left and black main ribbions white line where not aligning with gold line on board
Going straight in was not working
Going in at a slight angle with a push and a wiggle
Got all lines aligning
Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Okay, so I had the same problem. Only the back and open apps buttons worked. Went back in and realigned lines on the ribbon cables with the lines on the circuit board and BAMM, the home button works..
Puan 3
Yorum Ekle
Hard for me to recall. I think that the home button ribbon plugs into the charging port on that one. So you may just need to make sure they are plugged in all the way.
Puan 2
Yorum Ekle
No usefulness to this if you have to build a reputation to vote down unhelpful advice
Puan 2
Yorum Ekle
This one was an easy fix for me.
The connection to the mainboard is where the problem is.
There is a line eitherside of the ribbon cable, make sure the mark on the ribbon cable lines up with the ones either side.
Puan 2
1 Yorum:
Home button stopped working after USB ribbon cable replacement. This was the fix for me. I had replaced the USB ribbon cable but had not fully inserted the cable into the connector on the motherboard. Cracker666 correctly points out that the horizontal line at across the end of the ribbon MUST align with the two marks either side on the main pcba.
tarafından
Yorum Ekle
I noticed the same thing. I found the fix if interested still. There is a little piece that you have to put back under the plastic tab connected to the USB part. It must get connected back to the other connector part hidden under the plastic casing (tab).
Puan 1
Yorum Ekle
I replaced the same part a d now have the same issue. Did you find a fix
Puan 0
1 Yorum:
yes....just make sure you reattach the ribbon properly
tarafından
Yorum Ekle
Home button back,search all button not to work can u give me a solution of this problem?what can i do?tell me answer
Puan 0
1 Yorum:
The answer are in the comments up there bro....
Just make sure you reattach all the cable/ribbon properly in placed. If still not working...you need to replace it with new part
tarafından
Yorum Ekle
Do not push the ribbon all the way in, stop a little before the white line. If you push it too far it will not make proper contact with the connector. ;)
Puan 0
Yorum Ekle
My problem is that after time out of the screen,pressing the home button does not bring bacķ the dispĺay.The screen remains ďark no matter how many tìmes i press the home button.The only waý tò access the data again is to restart the computer again
Puan 0
2 Yorum:
Anybody know where I can get a ribbon cable for my home button?
tarafından
Anyone know where I can get a ribbon cable for my home button. Galaxy tab 3 7.0
tarafından
Yorum Ekle
I have the same poblem.
When l put back the old charge cabel the home button works fine.
The old cabel has 1.1 vesion and the new one has 1.0 on it.
l think thats the poblem...
Puan 0
Yorum Ekle
Under the plastic framework at the bottom, where the micrphone ribbon goes, there is a tiny rectangular connector from the home button, another ribbon. This connector plugs into the end of the ribbon that has the microphone from your new charging port.
Puan 0
1 Yorum:
I checked the ribbon to main board a dozen times, and no fix. This above was a 100% fix.
tarafından
Yorum Ekle
My tab home key stop working
Puan 0
Yorum Ekle
Does anyone have a picture of the connector? On mine the leftmost pins seem to be missing after sending it in for a battery replacement (Note Pro), and now the home button doesn't work anymore . Charging is intermittent.
Puan 0
Yorum Ekle
1. How to settle home button galaxy tab4, the button inside, stuck, cannot push. The charger still good condition?
2. How to reset for password forgotton without use home button?
Puan 0
Yorum Ekle
indeed easy fixed by reattaching the cable while wiggling it a bit.
Puan 0
Yorum Ekle
Yanıtını ekle
Christina Yung sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 35,169
