Ana içeriğe geç
The Apple Magic Mouse is a multi-touch mouse manufactured and sold by Apple Inc. It was announced and sold for the first time on October 20, 2009.
Magic mouse looses connection when not moved
Since a few days the mouse is acting weird. When it is not moving the connection will disappear, when the mouse is being moved again it will connect again. Everytime you want to use the mouse it takes a few seconds before it is connected again. Even when you pause 2 secondes to decide where to click on it will loose its connection! This behavior is the same on different MacBooks and Imacs.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try cleaning both the contacts in the mouse and the batteries. Look for leakage from the batteries. Use a slightly damp cotton swab (Q-Tip) with White Vinigar.
Also try a fresh set of batteries.
Is it any better?
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I tried all of your suggestions, and also the paper trick to make sure the battery's make a connection. But still not working :(
tarafından
You could try opening up the unit and check the solder joints for corrosion. Following this IFIXIT guide: Magic Mouse Teardown. You could just have a bad solder joint as well (battery contacts). Otherwise its time for a new one.
tarafından
Yorum Ekle
Yanıtını ekle
Michael sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 346
