Ana içeriğe geç
Micro Amp Battery power not working.
My MS-2R micro amp by Marshall has never failed me in the past but I recently noticed that when I try to use battery power it doesn't work. The wall input works and sounds fine but the battery power doesn't work. I have replaced and used at least 3 different batteries but still no solution.
please help, have a nice day
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Had same problem
I Took the thing apart and there was nothing wrong, I took the wires off the battery contacts and put them directly onto the battery and it worked. So I discovered the problem was the battery wasn't wedged up against the the contacts hard enough. So I cut a piece of card and folded it in half and wedged the battery in there. Switched it on and it started first time, never had a problem since
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Ahhh thank you!! This worked for me - I also had looked inside and all wires seemed fine - did as you suggested and bingo!
tarafından
Yorum Ekle
Yanıtını ekle
Jellyfish sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 3,690
