Ana içeriğe geç
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Soru Tümünü görüntüle
How to fix green/purple screen
I am in the process of a ipad 2 screen repair and I have two brand new lcds. For some reason one displays a tinted green and the other tinted purple, I have tried every method I know to resolve this problem. Now im looking for advice on what causes this issue. Would great if I can resolve this today
Bu iyi bir soru mu?
Puan 7
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Since no answer has been accepted yet, let me share my experience:
A/ First thing I try is disconnect then re-seat the Display Cable on both ends (using this guide): on the logic board and on the LCD. Then secure the connectors with Kapton/Polyamide tape.
B/ I test the contraption by:
1/ Gently re-seating the LCD back in place then flipping it again out of the back-case. In other words, I am causing the display cable to twist slightly and gently, and putting light stress on both connectors, to see if the change in hue occurs again. Please be gentle ;)
2/ Tapping slightly on the back of the iPad, especially around where the display connectors are located.
C/ If steps 1 AND 2 cause absolutely no change or flickering, I re-seal the iPad.
D/ If steps 1 OR 2 cause any kind of change in hue (ever so light) after or any kind of flickering, I change the display cable.
E/ I test again (repeat B)
F/ If steps 1 AND 2 cause absolutely no change or flickering, I re-seal the iPad.
G/ If steps 1 OR 2 cause any kind of change in hue (ever so light) after or any kind of flickering, I change the LCD.
From experience, 95% of cases are resolved without having to change the LCD.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
Hello I good smack on the rear case will fix a wonky coloured display..
Same thing happened when I was repairing one today even after a reseed of the connector it was a green screen. So I lifted it up and hit it a smack on the back and normal screen functioned..
Puan 3
6 Yorum:
Thanks for answering, ill give it a try tomorrow
tarafından
Cheers keep us updated
tarafından
Still not working I tried your method. Its not a loose connection or a grounding issue so I'm stuck
tarafından
If a really hard good smack does not work then it needs opened up and the lcd disconnect and reconnected if still a funny display after that then the lcd has gone bad
tarafından
I tried 2 lcds. One shows purple and the other shows green. The only thing I haven't tried is to restore the firmware.
tarafından
1 tane daha yorum göster
Yorum Ekle
I went to the Apple Store and they took out my screen
Puan 0
Yorum Ekle
The screen on my Apple IPAD2 changed from blue to pink/purple. Please help me with this problem.
Puan 0
Yorum Ekle
Hi,
Usually that problem is due to a bad connection of your iPad's LCD, what has to be done is:
- turn off your iPad;
- open your iPad (please watch the repair guide related to it);
- carefully disconnect (on both ends) the flex cable shared by the LCD and the Logic Board;
- carefully reconnect it, make sure it is well connected;
- try turning on your iPad to check that it is working properly.
If not than you should need a new LCD.
Hope it helps :)
Puan 0
Yorum Ekle
Yanıtını ekle
matthewlevy300 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 84
Her zaman: 29,844
