Ana içeriğe geç
The Dell Latitude E6500 laptop PC was released in August 2008. The Latitude has a 15.4 inch screen with a 500 GB hard drive
21 Soru Tümünü görüntüle
I need to disable the PW on my laptop...
On my old desktop, via the motherboard. There's a jumper pin to disable the PW. Is there one on a Dell E6500 Latitude, and do you have a schematic of the MB and a list of the surface mount jumper designations?
Hurry...
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Kevin Wilson, no there is not one. /most modern laptops no longer store the password in battery-backed RAM. those were the once you could reset by pulling the battery or a jumper setting. More modern motherboards use standard SPI flash chips to store the BIOS data. You should contact Dell and once you prove you are the rightful owner, they will help you. There may be a few ways to get it reset with your Service tag number. Check on here. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks for the assist.
tarafından
Yorum Ekle
Yanıtını ekle
Kevin Wilson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 2,029
