Ana içeriğe geç
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Soru Tümünü görüntüle
My MacBook Air Display is not working, it's broken? (I have a a photo)
I could put the photo now n.n, of my MacBook Air, I dropped it accidentally :( , but I want to know if my Display is broken or a cable inside it, what you recommend me to do?
Bu iyi bir soru mu?
Puan 1
4 Yorum
Can't access the image get: Unauthorized
tarafından
Kevin, use this guide to add images Adding images to an existing question
tarafından
There's the photo my friends:D
tarafından
Thanks for posting the image. Sadly I think old turkey is correct here your display has had it. You can also try connecting your system to an external monitor to help prove this. If the image is good on the external then its a sure thing. See if you can locate a full lid assembly while being a bit more in cost it will be a lot easier to replace.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Kevin, that is a broken LCD. Part of the electronics that is connected to your LCD panel has failed. You could try and see if you find something obvious, but most likely you will have to replace the panel. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Kevin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,273
