Ana içeriğe geç
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Soru Tümünü görüntüle
Soru Kapandı
Weird bubble effects when replacing lcd and digitiser
Just replaced lcd and digitiser on a mini, when i press on the screen with a little extra force than normal i get like bubbles all over screen, quite hard to describe tbh.
Cant figure it out :(
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Can you send a pic?
Do you get this aswell when you put pressure on the glass?
If so its the glass screen touching the lcd
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
Hi Con, i only get it when glass is seated onto the lcd after install (fully put together)
tarafından
might be they are touching. i lost the foam when installing, could that be it? thanks
tarafından
Yes I would say that's your problem then
tarafından
anyway i can diy replace ? :(
tarafından
You can buy foam for the edges but not to sure we're to buy
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 885
