Why is the drill not powering on?
Every time I try to turn on the drill it seems as if it is not getting any power. The chuck does not spin and the trigger doesn't budge.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You may need to charge the battery or replace the battery if it is bad. Also, if the direction switch is in the center position, the trigger is locked and the drill will not function.
Bu yanıt yardımcı oldu mu?
It is possible that your battery may not be charge sufficiently. Take off your battery and place it on the charger and wait for a full charge. Once fully charged put the battery back on the drill and check to see if the drill gets power.
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 270
