My chuck is not spinning?
Everytime I press the trigger the chuck does not spin, the battery has power, for your information. What possible things could be wrong with my drill?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I had a similar issue. When you pull the trigger the light came on but the chuck would not turn. No sound or smell, the chuck just didn't engage. When I took it apart I found there was a cold solder joint on the red lead to the motor which came loose.
Bu yanıt yardımcı oldu mu?
The trigger switch may be bad. It might also be a bad motor or a wiring problem.
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,726
