Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Soru Tümünü görüntüle
Soru Kapandı
Internal speakers not working
I have an iPod touch 4 and my internal speakers are not working to play music or streaming, but sounds do play for example ring tones. I have reboot the iPod, but the iPod will only play through external devices. Any thoughts on what the problem could be and how to fix it?
Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The ear jack could be faulty or it could be a problem with the docking port.
It sounds as though your iPod is in docking mode.
1) Clean out the docking port area carefully to make sure there is no dust or lint jammed in there.
Check for damaged pins, if you see bent pins then there isn't much you can do as the dock port is soldered to the main board and would cost you as much to replace the iPod as it would to fix the docking port.
2)If you are up to it, you can open the iPod and replace the ear jack. It is a small replaceable plug in jack so not a big job once you get inside.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 371
