My Blu Studio 6.0 screen broke, how do I fix it?
My phone fell down with the screen facing the floor and got cracked, the tactile still working but is really hard to see behind the cracked screen. How do I replace the screen?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
its really difficult to separate the LCD and the touch screen digitizer in BLU studio 6 HD d650a / d651u , I tried using playing card ,thinnest fishing line (very promising), to separate was able to remove all glass but realized that the lCD broke in the process
my recommendation is to buy online a lcd+digitizer+frame online then to fix this model phone will take exactly 10 minutes and will involving removing the screws in the back panel only
the lcd+digitizer+frame is approximately $65
regards
dan
Bu yanıt yardımcı oldu mu?
When i order my lcd+touchscreen+bezel(frame assembly) online how do I know its for my D651u???
My name is sharon Jones my husband bought me a blue for my birthday at Christmas. I drop it and broke the gladd ans would like to replace the glass. ogv c.f. v
Can you fix means lol
After you take the back off then what's next
my name is fidele my phone blu6.0 screen is broken
you will need a new digitizer to fix the screen places will tell you to get a new LCD but that is not needed if the screen shows up
Touch screen of my BLU studio 6.0HD D651u mobile phone is broken. Please help what should I need to repair it.
Here is the LCD with a Broken Digitizer in case someone with the digitizer wants to try and separate the LCD from it. The LCD ad is a "Or Best Offer". Make an offer. http://www.ebay.com/itm/271946932295?ssP...
The Digitizer is located here: http://www.ebay.com/itm/181794085093?_tr... if someone wants it.
You will also need the UV Glue to bond them together. Here it is on Ebay: http://www.ebay.com/itm/UV-glue-LOCA-Liq...
And you will need this: http://www.ebay.com/itm/Mini-Aluminum-UV...
Here is a video on how others separate the LCD from the Digitizer: https://www.youtube.com/watch?v=M2rHnk2C...
Hair dryer works very well. you need heat!
You can buy the parts on ebay it's about 60 bucks but make sure you get the both the glass+lcd frame. Once you have the part it's very simple to replace it.
Turn off phone
Turn it to its back n take off cover
Takes off any screws you see
Then you take your nails or guitar pick n in between the screen frame container and the body and go around till u get it off (u can tell where they are both separate) just be careful around the power and volume buttons. U don't want to rip those off
Once that's done take off the the big black ribbon and a small ribbon, so taking off two (if u look at your new part you can tell which ones are they)
Now you turn it over n heat that sucker up n use the same guitar pic to go around to take off the glass u Goin to have to do it over and over, then once that is off u take both the Glass n lcd out n put in the new one (there is a bottom ribbon sort of a tricky fellow but u must plug it in as well u will know when u see it).
Then heat the glass one more time so it can stick to he glue again. Put it back together and your good to go.
My blu sreen broke has a long line running across it and i cant work the phone ...who can i get to fix it
You have to get the screen replaced from BLU service center or you can buy new LCD screen online and get it fixed from mobile repair shops. However, I will suggest you to contact service center once and ask for the solution for broken LCD display.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 44,320
11 Yorum
I have a blu studio 6.0 hd d651 it fell on the corner and it cracked. I can still see everything but the touch is messed up. Do I need to buy a lcd and glass replacement or just the glass?
van R tarafından
I have a 6.0 lte done the same thing
katrina luttrell tarafından
Ok i got a blu 6.0 nd drop it nd it wont come on..plz help
Roro tarafından
I had a blu 6.0 it fell screen not broke but the back Button and home and menu buttons won't work. My husband's cell is exactly like mine but his seen is broke can we switch the screens from one to the other and make one good one
reginakaydorris tarafından
I have a Blu Studio 6.0 HD d650a I dropped my cell phone and a cracked and broke on the touch screen did some things that do work like my power button and my volume buttons butt my touch screen cell phone does not let me log into anything when I touch it how can I fix this I need step-by-step Direction what do I need to get to fix my cell phone device death only three buttons that works on my cell phone I don't have no problem with that is my power button and my up and down volume button those work pretty well I don't have any complains about that adjust my touch screen cell phone I dropped and they have to be cracked on my cell phone touch screen when I turn my phone on and try to touch the touch screen to log into anything like my things that added to my cell phone like in the Google App Store YouTube anything else that added to my cell phone I can't log into anything that login to their and I mean anything can you please help me and give me advice what should I do
Frances tarafından
6 tane daha yorum göster
