Ana içeriğe geç
GM tarafından üretilmiştir. Bu, bir "kara yatı"nın sekizinci neslidir!
Diagram of the fuse box
I can't find the trunk fuse on my Pontiac Bonneville
Bu iyi bir soru mu?
Puan 1
1 Yorum
I'm having the same problems. Can't find the same fuse box for the car . radio etc.. Someone help up please. I'm no dumbie when it comes to cars. But I'm stuck. Looked everywhere..
Ok. The small fuses are located under the steering wheel where the brake pedal and gas pedal are at.. As far as where the trunk fuse. I can't help there.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@carson_13, benny,Niki , There are two fuse blocks in your vehicle: the driver’s side and passenger’s side fuse blocks and the 3rd is under the hood engine compartment. I believe trunk fuse to be in fuse/relay box passenger side under dash(may be able to access easier by removing glove box liner). Radio fuse shows position 8D, Driver’s side fuse interior block, Pg.6-62/6-63, in the manual link posted below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://justgivemethedamnmanual.com/wp-c...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Were would the window fuse be located at in the driver side one or the passenger side fuse boxs
tarafından
Yorum Ekle
Yanıtını ekle
Niki sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 60
Her zaman: 7,121
