Ana içeriğe geç
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Soru Tümünü görüntüle
Soru Kapandı
replaced logic board, and still no power
Greetings, I just replaced the logic board in my Macbook with a used, supposedly working board, and put it back together properly, and no power. Mag safe adapter is orange when attached. What is the most likely problem here assuming that the board is good? Power switch bad? If so, can I test it somehow? Or something else? Any info will be appreciated.
Thanks, David
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would try replacing the MagSafe board. Its possible the connector is bad.
Are you sure the logic board is good?
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
See this previous Question and Answer.
If this answer is acceptable please remember to return and mark it.
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 107
