Why is my touchpad not responding anymore?
The touchpad isn't responding to anything right now but I can use a mouse in the USB port. How can I fix the touchpad?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Does your laptop have a keyboard shortcut that disables the touchpad? I think off the top of my head Toshiba uses the Function + F9 key to turn on and off the touchpad. Some even had a button right next to the touchpad that performs the same function.
Bu yanıt yardımcı oldu mu?
Go to Mouse settings>touchpad >additional settings on the right side>>Advanced>advanced featured settings>device select>touchpad>>apply
You may need to update the touchpad's driver. Which can found here at the Toshiba Software & Support page
That’s a good idea, but that’s not always the case.
One of the issues is that your laptop is old and the laptop dies / runs out of battery, so the mouse pad goes filty and stops working . The only way I’ve found is that you use a usb and connect and mouse to the laptop.
My Toshiba satellite was working with the mouse and I touched some buttons and then I noticed that the touchpad was not working. I tried touching the buttons tlFN and f9 and all the others and nothing worked but what did work was a simple reboot so if you're having any kind of issue usually just reboot your PC and everything will get back to normal at least this time it did my Touchpad started working fine with a simple reboot.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 24
Her zaman: 11,221
