Why can't I hear anything from my tablet?
I can't hear anything from my tablet and my volume is on max. I can hear just fine when my headphones are in though. Why can't I hear without my headphones?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Why won't my tablet produce sound?
Following the instructions in the link above fixed my problem. I reset my tablet, and as soon as the screen went dark, I pressed the volume up, and held it until it finished reseting. Then I was able to turn up the volume from all the way down, to a reasonable level about half way up, which is much louder than I've ever been able to set it before.
Bu yanıt yardımcı oldu mu?
The speakers are probably not working properly. Check out the the speaker replacement guide for more information.
It is likely your speakers require replacement. However, to be certain you should follow the steps in the troubleshooting page.Samsung Galaxy Note 8.0 Troubleshooting
I can't hear anything on my tablet and it is at the top volume, I also can't hear it when my headphones are in what do I do to fix the sound?
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 10,029
6 Yorum
Same problem. It starts out fine, but then fades until I hashes to turn it up all the way, regardless of whether using headphones or speakers. Worse, it often displays a warning about how listening at high volume can be harmful. I don't think this tablet is capable of producing dangerous volume. I can't hear it over the sound of of a quiet fan sometimes. I can usually fox the problem for a while by reseting the tablet, but that should not be necessary.
David Lloyd tarafından
System sounds, although I have them set as low as possible, are often extremely loud.
Why don't i hear anything on my device?
pringles1934 tarafından
To be honest I don't
Riana Andrade tarafından
Why can't I hear anything from my tablet I tried everything
I can't hear calls it's an app I have anyway I can't hear YouTube music vids I can't hear anything in general it's not just one app o can't hear it's EVERYTHING!!! Someone tell me what to do
1 tane daha yorum göster
