Ana içeriğe geç
The HTC Droid DNA is an Android-based, 4G LTE-capable smartphone designed and developed by HTC.
Text message font size keeps increasing
Since I updated my phone, everytime I go to send a text message I set the font to small, but when I go back to the text thread the font size is back to its original size. In the font size menu it says its set to small. Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Something that usually works to solve this are to simply clear your cache in the settings under the messaging app. You can do this by going to settings>apps>find the messaging app and then select clear cache. If that still does not work you can clear the phone's cache through a stock recovery. You will not lose any data so don't worry. You can do this by following these steps:
1. Shut down the device.
2. Hold down the volume down and the power button simultaneously until you boot into the HBOOT Menu
3. Select the RECOVERY option using the volume buttons
4. Your phone will show the white HTC screen, then you will see a black screen. It will take a while but it will say "Failed to mount SD" four times. Wait until it turns into a red triangle with an exclamation point inside the triangle and from there, hold down the Volume Up and then press the Power button. You will see a small list, this is stock recovery.
5. Select wipe/cache.
I hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Sam Gallagher sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 140
