Ana içeriğe geç
This page contains replacement guides and a troubleshooting section for the Craftsman Scroller Saw Double Insulated 5/8" Stroke-Variable Speed (Model 315.10721). This handsaw was manufactured in 1979 by Sears, Roebuck and Co.
7 Soru Tümünü görüntüle
Why is the saw blade bouncing when I am making a cut?
When making a cut the saw blade seems to bounce up and down. It will not make a clean cut through the material. I have tried using different speeds but it is still bouncing
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Wrong blade for material - too big, too large, too dull.
What material are you cutting. How thick is the material, what type of blade are you using, how many teeth per inch. The answer to all those questions contains the solution to your problem.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Riley Hilliker sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 84
