How Do I Fix a Leaking Solenoid?
My Etha is leaking from the solenoid. How do I fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
There are two common causes. First, turn the pressure on the regulator down and check for leaks again. If the output pressure of the regulator is too high, the solenoid may not be able to handle the extra pressure. If it still leaks, you will most likely need a replacement solenoid. These can be ordered from Planet Eclipse, or your local field might have one. Once you have a new solenoid, we have a replacement guide for you here.
Bu yanıt yardımcı oldu mu?
Hay all I have a vibe marker and the solenoid has exploded is there anywhere I can get another 1 from and I am in Western Australia cheers
Mine don't hav a gauge on it
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 17
Her zaman: 2,701
