Ana içeriğe geç
A tablet released by Toshiba in July 2011, identified by model number AT105-T1032.
12 Soru Tümünü görüntüle
Why is my Thrive not charging?
I have tried everything from buying a new charger to replacing the battery, but nothing works. What could the problem be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
1 Yorum
I have been having the same issue, though just yesterday I turned on the tablet and it was charged. I have quite a lot of Apps, and I began to wonder if low disk space could interfere with some software aspect of the charging/battery monitor process.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It sounds like you have a possible charging port issue. Try replacing your charging port using the charging port replacement guide.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
If you can find the stand. you can test to see if it is the charge port. The stand has a power adapter port built in. It has to be the stand with the HDMI port in it. I have found the batteries really need a power save app.
Puan 0
Yorum Ekle
There is a resistor, possibly being used as a fuse, that goes out on most of these units. Replacing the resistor seems to solve the problem. If you can power / charge the tablet from the dock but not from the charge port, it is probably because of this resistor, rather than the charging port itself. I have repaired hundreds of these tablets with this issue. If requested, I will try to post a photo of the resistor in question.
Puan 0
3 Yorum:
Could you post a picture of this resistor and how to fix it? Thanks
tarafından
Please post picture of resistor location for charger port for the thrive tablet, thankyou
tarafından
Please post pic
tarafından
Yorum Ekle
Please point out resistor that acts as a fuse on power port board, this is for a Toshiba Thrive tablet.
thank you.
Puan 0
Yorum Ekle
Yanıtını ekle
Kason sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 2,108
