I am losing antifreeze and there is no obvious leak.
Car is losing antifreeze and there no signs of leak under the car. Just replaced thermostat. I was told it could be going into motor, what does that mean and how do I know?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Check your lower radiator hose from the radiator to the engine. There might be a small leak that is dripping coolant without you noticing. Also check the thermostat housing, which can crack and develop a small leak that can evaporate before you even notice drips, etc.
Be sure to check your oil frequently for any signs of contamination. If the oil is getting discolored (e.g. milky, lighter than normal, greenish or tan sheen, weird burnt smell), it could indicate a leaking head gasket or other internal engine leak that would need to be repaired immediately.
Bu yanıt yardımcı oldu mu?
Do you notice your car running any differently, such as any hesitation on acceleration, odd sounding idle, etc? If you were told that your motor is taking antifreeze, that could mean you have a blown head gasket.
My chevy cavalier had same issue- It was the cap for the coolant tank- car is 16 yrs old -couldn't handle the pressure (grin)
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 155
