Ana içeriğe geç
4 inç ekran / Farklı renk seçenekleri / 3 farklı modelle piyasaya sürüldü / 16, 32 veya 64 GB kapasite
iPod will not turn on?
I was using the iPod Touch (16GB, no camera) when it suddenly turned off and would not turn back on. Tried charging it for several hours and no change, it still won't turn on. Could it be the battery needs replacing? Seems the logical place to start but wasn't sure?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 7
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try the easiest first....try cleaning out the dock connector with some canned air to see if there's anything keeping a good connection from being made. If that doesn't work, open it up and see if anything has come loose/broken etc.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Have you tried plugging it into the computer to see if it registers? If it gives you an error, maybe google the error to see the meaning. Just a thought
Puan 1
1 Yorum:
i have the same problem with mine. t does not register when i plug it into the computer, also the home button did not work prior to this. Help?
tarafından
Yorum Ekle
was there a solution? if so please list what it was. Thank You!
Puan 0
Yorum Ekle
mine dosnt reg wen plug into laptop either
Puan 0
Yorum Ekle
Long time since this was posted, but I had a similar problem. iPod would not turn on, nor take a charge.
I was able to fix it by plugging it into a power source then pressing the home and power button and holding both for about 30 seconds. The Apple logo popped up and it would now take a charge and power on.
Puan 0
Yorum Ekle
How do you restore iPod when it’s locked showing USB to iTunes and says can’t restore, no network
Puan 0
Yorum Ekle
Yanıtını ekle
Kelly P sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 2,920
