Ana içeriğe geç
Button makes electronic "click" sound when pressed
Here's a weird one -- I've got a 14" iBook G4 that makes a subtle electronic click sound when the button is pressed. It also makes this sound when the space to the LEFT of the button is pressed, like just pressing on the plastic of the topcase is triggering it as well. Very odd, I know. The sound almost sounds intentional, as if it's supposed to happen, and it's very subtle and high pitch, like two pieces of glass or metal lightly tapping. It's kind of pleasant, actually. It's definitely an electronic sound.
Anyway, I've had a few machines do this over the last couple years, and while it's not a huge horrible problem, it would be interesting to know what causes it. The machine has a fresh OS, so it's not a tweak to the button settings, etc.
Bu iyi bir soru mu?
Puan 3
2 Yorum
Does it sound like an HDD sound?
tarafından
when you say "button", are you talking about the power button, or the trackpad button?
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
The way the power button is installed I would suspect a mechanical rubbing and release is the cause of the click. Pressing on the top case would have a similar result I should think. Ralph
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
He says it's definitely mechanical
tarafından
Yorum Ekle
If you look in System Preferences>Track Pad>Clicker you'll find the solution. Clicks like the clickwheel on an ipod. OR not, depends on the setting.
Puan 1
1 Yorum:
That's a good thought, but I remember checking that, and it wasn't it. The clicking didn't happen all the time. Since I know it wasn't the hard drive either, I can only assume it was some kind of electrical flaw in the topcase. Ah well, I'm not going to lose any more sleep over it unless I come across a similar machine.
tarafından
Yorum Ekle
Maybe a simple PRAM reset will work.
Puan 0
6 Yorum:
Tried that, good idea though.
tarafından
If it's definately hard drive then verify/repair/replace
tarafından
I'm not convinced...it makes the sound when the button is pressed...I've never known hard drives to make a distinct sound on command.
tarafından
I have a feeling that he needs to open it up and take a look.
tarafından
Sorry, I meant to say it's definitely NOT the hard drive, but I forgot the "not". :-) It was a minor issue and I sold the machine, so I'll have to wait for the next one to solve the mystery. Thanks for the brainstorming though!
tarafından
1 tane daha yorum göster
Yorum Ekle
Now that my trackpad stopped clicking by itself, I'm not sure what's going on. It seems the button to select" clicker" in system preferences enables the trackpad to behave like the select button below it.
Puan 0
Yorum Ekle
Yanıtını ekle
rdklinc sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 2,530
