Ana içeriğe geç
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Soru Tümünü görüntüle
Stripped Screw on Antenna Plate
So just as the description says, when putting one of the hex screws back in on the antenna plate, I over tightened and stripped one of the screws. And when I say stripped, I mean I stripped the threads, the screw just spins now and doesn't hold, it just falls out. Is there any solution for this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Were you able to solve this problem? I'm having the same issue
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Usually it's possible to grab the screw with a pair of needled nose pliers. If not, you might have to drew the screw out using a drill.
Hope it helps!
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
There's some really cool pliers designed for just this problem!
Screw Extracting Pliers
Screw Extracting Pliers Görseli
Ürün
$19.99
Puan 2
4 Yorum:
Its not the hex part thats stripped, its the threads female threads that are stripped.
tarafından
To get it to hold back in place, you can always try using some Loctite or another type of threadlocker. Just don't get the super high strength stuff, or you'll do more damage.
tarafından
Thats kind of what I was thinking...Guess I'll give that a shot.
tarafından
Were you able to solve it? I have the same problem
tarafından
Yorum Ekle
Yanıtını ekle
betts211 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 405
