Ana içeriğe geç
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Soru Tümünü görüntüle
Stripes on MacBook screen
Suddenly some horinzontal stripes appeared in the screen of my macbook unibody late 2008. It startes with a little part of the screen but it has been increasing.
Does anybody know what this can be?
Someone said to me that it could be the lvds cable, another can be the screen.
You can see the stripes here
[IMG]http://i61.tinypic.com/25slidz.jpg[/IMG]
Thank you!
Update
Hi Dan! The computes has never get wet. I opened the bottom cover and the lvds connector looks fine... and the gpu I don't dare to open the gpu processor to see if it's in a good condition.
Bu iyi bir soru mu?
Puan -1
3 Yorum
If I connect and external monitor the image is perfect, so I don't think this could be a problem with the graphic card.
tarafından
That leaves the LVDS cable and connector. Did you open the cover and make a good inspection of the connector in case the cable has become dislodged?
tarafından
hi Dan! It looks fine and in its right place :(
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This a pattern I haven't seen before so I'm not sure if the LVDS cable or if the GPU circuitry on the logic board is having a problem. In any case I don't think you have a screen problem.
Did you get the system wet? I would open the bottom cover and make a good inspection of the GPU chip and the LVDS connector.
Update
OK, I guess that leaves the LVDS cable has gone bad. Here's the IFIXIT guide to work you though the process: MacBook Unibody Model A1278 LVDS Display Cable Replacement.
Take your time with the heat gun and don't run it too hot as you want to soften the glue not melt the plastics.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
swheel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 275
