Ana içeriğe geç
Updated version of the Kindle Fire 7" tablet by Amazon with 1280x800 HD display. Released September 2012. Repairing this device is straightforward.
Kindle wont turn on,half boots when plugged in? definately motherboard
Basically,
Kindle shut off. became unresponsive. If i plug it in it gets to the 'kindle fire' screen then turns off after 4 seconds. Ive tried all resets to no prevail. I decided I would pry off the back and check nothing was loose in the motherboard, after blowing the dust out and pushing everything down the kindle rebooted and started! I replaced the back and then tried to turn it on again..same problem as before, unresponsive! guess my question is, which part of the motherboard is causing this problem?! as i know its something loose as it restarted before! please help! thanks :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
It may not be the motherboard. It sounds like you have the same problem I do. My daughter dropped it and it started doing what you described. I changed the motherboard and it's still doing it. Now I'm at a loss because, unless there's a component of the screen that could cause this, I have no idea what could be causing it. I thought for sure it was the motherboard.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
leanneathenadunmill sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 311
