Ana içeriğe geç
Hard Drive Replacement Data Transfer
I am about to purchase a large HD for my iBook. What I do not have any confidence in is my ability to recreate the system, applications, and configurations the way that I have them on my current drive. Is a disk image what I should be searching for information on to create an exact copy of my existing drive on my new, larger capacity drive?
I read somewhere the easiest method is to somehow place my existing HD in an external drive case and after placing the new drive in my iBook, transfer from the old internal (residing in the external case) to the new internal HD. Is this possible?
Can anyone tell me how best to do this or where to look for this information? Thank you!!
Curtis
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It's really simple actually, all you need to do is buy an enclosure, then put the new drive in there, connect to your computer, and use SuperDuper to clone your internal drive to the new one. Then replace the hard drive and you're set to go!
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
agree + That's the way to go...
tarafından
I purchased a firewire enclosure because I've run into a number of postings that firewire is the only external that an iBook of this kind can boot from. I found following the iFixit pdf on cloning data with SuperDuper worked perfectly! The instructions were linked to in the hard drive page I ordered from on iFixit. No issues or hiccups with the data transfer. (If replacing the drive could only be so easy!) Thank you and thank you for your subsequent advice on the replacement of the HD.
tarafından
Yorum Ekle
Yanıtını ekle
crtolson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,415
