Ana içeriğe geç
The Blackberry Torch 9810 is an updated version of the 9800 Blackberry
5 Soru Tümünü görüntüle
Why won't my phone turn on?
I put my phone to charge last night and when I woke up it was off. I tried taking out the battery, but that was useless. What do I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
2 Yorum:
me too I have the same problem, when I change my Sim Card yasterday, my phone did not open up to now
tarafından
hi pls I need help with my blackberry torch 9810 which I got from someone. The next day I got a new battery for the phone and when I put it in it started blinking the red light and didn't stop I tried leaving the phone to charge but no solution even while the charger is plugged it blinks red light. I brushed the logic board with a solution and dried it. I was in the middle of trying to leave to phone to charge for 2 hours and then pull out the battery for 15 minutes before putting it again for another 2 hours. pls can someone help me pls I would be really grateful, thank u
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
First check to insure your charger cord is not ruined. Many times this can be the main reason why your phone isn't charging. Try using a friend's cord or an additional one that you may have laying around. If this still doesn't work you will probably have to replace your battery. That is an easy fix! Hopefully that works, but if not your logic board must be replaced.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Heat the panel with paste if it dosnt work change the flex
Puan 0
Yorum Ekle
when i turn on my phone it's say "error 507".what do i do ?
Puan 0
1 Yorum:
Open blackberry device manager on PC, connect blackberry device using USB cable without battery and continue repair option on PC with blackberry device manager.
tarafından
Yorum Ekle
Yanıtını ekle
Jocelyn Adorno sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 3,043
