Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
iPhone 4s bootloop after screen replacement
Just changed the screen and the iphone now is in bootloop with the apple logo. The logic board apparently has no problem (I checked with macro lens). I tested the lcd in another Iphone and it perfect work. This is a video with the problem https://www.youtube.com/watch?v=p-dz2SDV...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi.. I tried a new battery, that's what caused the boot loop (3600mah)..
I fixed this on this phone.. Maybe entirely different cause for some one else..
I noticed a power drain last night after swapping the gutt's to a new shell.. Everything worked fine, so presumed the battery was shot.. So changed it for a high powered battery, which seemed to work fine.. Was about to call the client to say its fixed, one last test.. Boot loop!!
Any way.. After searching lots of posts like this one decided to check for shorts.. Took every thing back out, tested the board while it was unscrewed, but still in place.. It worked!
So screwed it back together testing the boot sequence with every few screws.. The very last connector.. Front facing camera flex! Boot loop.. If I unplug it while in boot loop it works fine and boots up.. So I'm just waiting for a replacement flex and preying the fault is the flex and not on the logic board.. Fingers crossed
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Surely you know that there isn't such a thing as a high powered battery for a iPhone!
The that so called high power battery would probably cause more damage than good.
I would just swap it out for a good proper battery and take no chances
Puan 1
Yorum Ekle
Is There anyone who can help me?
Puan 0
Yorum Ekle
Apparently Not... I have the same problem - iphone 5 :(
Puan 0
Yorum Ekle
Hello have you tried a new battery that would be the first thing til do
Puan 0
Yorum Ekle
Yanıtını ekle
Marco Micheli sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 865
