Ana içeriğe geç
ASUS PadFone X, kolayca 9 inçlik Full-HD LTE tablete dönüştürülebilen, 5 inçlik Full-HD LTE Android akıllı telefondur. ASUS bu cihazı 2014 yılının Haziran ayında piyasaya sürmüş olup, cihaz T00D model numarasıyla tanımlanmaktadır.
Why does my battery drain so quickly?
On other smartphones that I have had, the battery would last a day. However, with my Padfone X, the battery only lasts a few hours before it needs a charge. Is there something wrong with my phone? Do I potentially need another battery?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There are several potential factors that could greatly reduce your battery life. The display uses the most battery power, so to start it is recommended that you turn down the brightness. Also check for any applications that you are not using, but are still running in the background. Close these applications. If you are not using WIFI, you can turn it off so your phone is not constantly searching for a signal. After making these changes, if your battery still
drains quickly, then you may simply have to replace the battery.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Yanıtını ekle
Andrew Smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 1,081
