Why am I not getting sound from headphones when plugged in phone?
When I plug my headphones into my Motorola Moto G headphone audio jack, no sound is coming out of the headphone speakers. What could be the problem?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
First check and see if your phone is under warranty. If not under warranty check the volume settings. If volume is set correctly try turning phone completely off to reset. Next try replacing the headphones or accessory you have plugged into the jack. If there is still no resolution the jack may need to be replaced.
Bu yanıt yardımcı oldu mu?
put phone into safe mode then delete all apps then restart phone then if it doesnt work do it again but delete all apps that you have recently downloaded
or dip jack tip in slight water dry a little insert again make sure your not drowning the piece your just trying to restore the conductivity of the jack itself
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 9,198
1 Yorum
I was watching a video on my laptop and it was working fine and after that there was no sound please help
Taymore Anderson tarafından
