Ana içeriğe geç
The 2008 Nerf N-Strike Recon CS-6 is a customizable, manual, clip-fed dart blaster sold by Hasbro.
7 Soru Tümünü görüntüle
How do I remove the magazine?
Instructions for removing the magazine from the gun.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
10 Cevap
Filtre ölçütü:
En Yararlı Yanıt
To remove the magazine there are two buttons located on each side of the gun. Use both hands to pull back both buttons at the same time, and then the magazine should simply fall out.
Bu yanıt yardımcı oldu mu?
Puan 5
2 Yorum:
yeah bro its easy
tarafından
Which side are the buttons on
tarafından
Yorum Ekle
Yellow model: Pull the grey slide mechanism back. Open the black hatch. Push down on the magazine while sliding the two orange unlock buttons.
Puan 4
2 Yorum:
works for recon mkII as well
tarafından
This is the answer I was looking for! Thank you! Just pulling the release buttons did not work
tarafından
Yorum Ekle
Pull the slide back and pull the orange release next to the magazine
Puan 2
Yorum Ekle
How do I remove the magazine if the slider is broken and cannot slide back?
Puan 1
3 Yorum:
Try firing the gun
tarafından
smash it on your sofa like a madman
tarafından
If the cover of the sliding mechanism comes off, use a long thin screwdriver and push it through the holes in the long slits, and then pull that back. If the slide wont pull back, try firing the gun and then pulling back. If that doesn't work, open up the blaster (please record what you're doing it as you're doing it in case you cant easily re assemble it) and try and see if its jammed.
tarafından
Yorum Ekle
I have placed my darts of my recon cs-6 accidentally but i cannot open it because it is too hard i cant use the opener
Puan 1
1 Yorum:
:o its jammmedso hard?
tarafından
Yorum Ekle
https://www.youtube.com/watch?v=pU5waRnk... Watch this and see
Puan 0
Yorum Ekle
The orange button near the trigger will release the magazine
Puan 0
Yorum Ekle
my slider is broken and i cant release the magazine
Puan 0
1 Yorum:
me either it is soooo jammed that i am poop
tarafından
Yorum Ekle
You have to pull the reloading trigger on the top and push the button on one. the pusher)
Then take out the mag.
Puan 0
Yorum Ekle
My magazine won't come out of the
Puan 0
Yorum Ekle
Yanıtını ekle
Asad Qureshi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 24
Son 30 gün: 83
Her zaman: 34,276
