Ana içeriğe geç
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
My iPod is corrupted.
hi whenever i plug my ipod into itunes, it seems to be corrupted. I have restored it and all that jazz and it isent working, i have also tried to uninstal itunes but i dont think it really worked because when i reinstalled it, it had all the music in the library. help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
frenchiekatie, the very first thing I would start with to clean the dock connector. Use some compressed air, isopropyl alcohol and a small non-metallic pick i.e. toothpick. Make sure that your pins are not corroded, bend or broken. After that, place your iPod into diagnostics mode and see what errors (if any ) you will get. To see how to place it in diagnostics mode and what the tests mean, check on here. Get yourself a USB-to-Zif adapter, disassemble the iPod using this guide. Check all your connections and make sure they are properly seated. If they are, remove the drive (if you have a USB-to-Zif adapter, try and access the hard drive with that. If your hard drive is accessible and the dock connector is okay, you most likely have logic board issues and may need to replace it. not a terrible job and most certainly not expensive. cheaper that a new iPod for sure. hope this helps, good luck
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
what are logic board issues? none of it seems to be working.
tarafından
perhaps if i clear all the content of it it may work again.
tarafından
Yorum Ekle
Yanıtını ekle
frenchiekatie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,702
