Ana içeriğe geç
Small black headlamp made from waterproof materials with an elastic headband.
Why is my headlamp not turning on?
My headlamp won't turn on! How do I resolve this issue?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
The headlamp fails to turn on after rotating the lens piece to the on position. If this is the problem, either the batteries may be drained or defective and will need to be replaced or the 3V incandescent bulb has burned out and will also need to be replaced.
Problem Remains Unresolved
If replacing the batteries and bulb fail to remedy the problem the circuitry of the headlamp may be fried. If this is the case, the headlamp is unsalvageable.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Every time I’ve had this problem it has been solved by removing corrosion from the copper terminals. With a pocket knife, scrape the contacts until they are shiny again, including the contact under the lightbulb. I also bend the contacts out slightly.
Puan 1
1 Yorum:
Marvellous, worked a treat. Thanks!
tarafından
Yorum Ekle
UNWRAP THE BATTERIES… Sealed in a plastic wrapper…
Puan 0
Yorum Ekle
I added some tin foil on the negative pole of the three batteries, a hack I learned researching why my Mac keyboard kept failing to connect. I was about to throw it away and now it works fine.
Puan 0
Yorum Ekle
Yanıtını ekle
Mike sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 118
Her zaman: 17,770
