Ana içeriğe geç
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
Volume slider broken and stuck on the loudest settings.
I dropped it and now it's broken and i am unable to tune down the loudness. The volume slider works fine I am able to push it up and down but the volume is stuck at the loudest setting. I want to know if i can fix it myself or do i need to send it for repairs.
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There are several things that are likely to cause this problem. The first is the external volume slider. This is the one that you physically move with your finger. There is a tab on the inside of the slider that aligns with a tab on the internal slider. If either of those tabs are broken then they need to be replaced. If the outer one is broken then you just have to replace the outer volume slider. This would be a pretty easy job. If the inner one is broken then it would be a very hard thing to replace. It is soldered to the motherboard in a way that makes is very hard to desolder.
If I were you I would at least remove the back cover to take a look at the volume sliders and see if they are broken. It's possible that they have just fallen out of sync with each other after being dropped. If you do decide to take it apart be very careful when you remove the back case as there will be a ribbon cable that is still attached.
Bu yanıt yardımcı oldu mu?
Puan 7
5 Yorum:
It appears that you should just never drop the damned thing then.
tarafından
you drop on accident sometimes don't you drop stuff
tarafından
I didn't even drop anything. I was turning up the volume so I can hear music,but when I tried to lower it, it won't move.
tarafından
what are the chances or breaking the internal volume piece
tarafından
I tried to fix the volume control and i noticed that the little plastic tab that sticks oit of the internal volume control was broken off but even when i tried to adjust it nothing changed
tarafından
Yorum Ekle
Yanıtını ekle
Jared Lim sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 79
Her zaman: 25,108
