Re: Can you operate without door
This is answer to Elizabeth Holland,s question. Please indicate you have read it. I am worried you might try using the microwave without the door. Thanks Ralph
Bu iyi bir soru mu?
Bu iyi bir soru mu?
(Elizabeth's question.)Can a microwave work without having a door on it? Our door was warped from gas burner below. We ordered a new door with the understanding that it could be returned if it did not work when using microwave. I was then told after trying to return it for the money to go toward a new microwave. I was then told they could not refund our money since the door was not essential for microwave to function. Is this a reasonable reason for not being able to return a new microwave door that was never used? Please respond as I just do not understand their reasoning for not allowing us credit .
/ Thank you, Judy O'Rear
(My answer) Do NOT under any circumstance operate a microwave without a door as you can be blinded or KILLED by the microwaves. Without the door anyone within range will be COOKED. They should absolutely refund your money--tell them you know you cannot safely operate a microwave with the door off. A safety circuit should prevent the unit from operating without the door.
rj713, 23 hours ago
Bu yanıt yardımcı oldu mu?
There are 3 switches that the door MUST activate when closed. It WILL NOT operated without the door. They are feeding you a line of BS RE the door not being "essential". Time to file a dispute with your financial service.
Hi,
The door forms part of the Faraday cage surrounding the oven cavity to ensure that no harmful microwave radiation can escape from the oven when it is operating.
It is part of the safety features incorporated in the oven, along with the oven door interlock switches, to protect the user.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 351
