Solution for distorted audio?
I've never had a problem with my phone's audio until recently where it's become distorted and quiet, what could have caused this problem and is there anything I can do to fix it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
There are a few things that can cause your audio to stop working properly, and each requires a different fix. The first thing you should do is make sure that the holes over the speakers aren't just clogged. Look on the back of your phone, and see if there's dirt in the small line of holes near the bottom. If there is, running a fine needle through them should solve the problem. If that doesn't help, try making sure your software is up to date, because this might also be causing performance issues. If there still isn't any improvement, your speakers have probably blown out. You'll have to replace them.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 132
