How do you fix a few unresponsive keys on keyboard?
A few keys on the keyboard are unresponsive. Press the "P" and nothing happens. Press the "I" all is well. Hmm...
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi Sean, try dismantling the keyboard, there is a lvds cable which is connected to the mainboard. Disconnect it and clean up your keyboard.
Also use an eraser to rub on the LVDS cable connector of the keyboard.
If all fails, consider getting a replacement keyboard module from ebay.
Bu yanıt yardımcı oldu mu?
Answering due to poor answer quality
These Lats have a keyboard that comes out from the top with 2-3 screws after removing the keyboard volume control cover. Once you remove it, slide it out and it comes right out. More often then not, the keyboard is bad. However, reseating it can help on this series.
If the issue is still there, it needs a new keyboard. Sometimes cleaning helps, but with Dell, it's usually a bad matrix.
Dirt or debris may have gotten under individual keys, which makes them not make good contact. Individual keys can be carefully pried up and then cleaned manually or with a can of compressed air. This usually solves the problem for me.
با فشار هوا بهترین راه پاک کردن است
بیا بخورش جنیفر لوپز جوون بکنم اون لومبهاتو
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 608
