Ana içeriğe geç
Eylül 2011'de piyasaya sürüldü. Ekran - 800 x 1280 piksel, 9,4 inç. Yonga seti - 1 GHz Nvidia Tegra. 5 MP kamera. Android işletim sistemi, v3.1 (Honeycomb), v4.0.3 (Ice Cream Sandwich) sürümüne yükseltilebilir.
WIFI does not work
Hi,
I can't connect to the wifi at home, it detects the signal but it does not connect to it. It thought it was my wifi's home, but at work it happens the same. I also went to another person's house and the wifi does not work.
I put the password again, disconnect and connect the wifi, but nothing happened.
Bu iyi bir soru mu?
Puan 0
1 Yorum
polharder, has it ever worked for you? Did you change anything in your settings lately
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try going to an open WiFi location (an AP without any security password). See if it can connect to it (altering your AP settings; going to McDonalds or Starbucks Coffee house etc...)
If it does work then you'll need to check the case of the password as upper & lower case are different here (even unicode characters). Also make sure the password is not overly long as some devices can't parse the key longer that 10 digits/characters.
Next check what security option you are using on the AP and make sure your device can do it. As an example some older devices can't to WPA 2.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
polharder sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 37
Her zaman: 611
