Ana içeriğe geç
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211 Soru Tümünü görüntüle
Galaxy note 2 stopped charging
the charger snaps into the port perfectly but it doesnt charge. I bought a new battery and the phone works with that but still doesn't charge. What do you suggest?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Hi,
Did you try with another charger ?
Maybe, you could check if the charge board is still correcty connected.This video show you the dissambly process and the charge board at 4:59.
Good luck.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
The above might be correct or it might be the fact that the charger port itself is dirty.
This happened to my phone, dust had gathered up and stopped charging my phone. So try clean it, if no luck, go for the guide above.
Ryan
Puan 0
Yorum Ekle
I've seen a lot of issues with the Note charging ports physically coming off of the board. I would open it up and make sure it's connected well. You can buy a replacement charging circuit board - they run about $7-15 and try it. That would be the easiest solution, and would likely fix any issues. If that DOESN'T fix the issue, then you have real problems.
Puan 0
Yorum Ekle
Yanıtını ekle
Keith St Jean sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 296
