Why is my device not turning on?
I keep pressing the power button to turn my phone on and nothing is happening. What do I do?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
One of these should help.
1. Drained Battery
If your phone will not turn on, the battery may be low in charge. Plug your phone into the charger, wait 5 minutes, and try turning the phone on. If that does not work, wait until the phone is fully charged, then try again.
2. Bad Battery
If your phone will not turn on after you charge the battery, the battery may be dead and unable to hold a charge. In this case, you will need to replace the battery.
3. Battery Connection
Make sure the battery is connected correctly. Open the back case, remove the battery, and put it back in. Try turning the phone on again.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 358
