Ana içeriğe geç
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
71 Soru Tümünü görüntüle
Samsung 46 inch LCD TV takes 3 cycles to power on?
I have a Samsung LN46A550P3FXZA 46 inch LCD TV. Screen shows a cloth-like image until the picture arrives on the third cycle. Capacitors appear fine, no doming on top
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
1 Yorum:
Bobby, can you explain this "Screen shows a cloth-like image "a bit better. Or post an image of your screen with your question....
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Bad capacitor.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I changed the capacitors and the problem is still there
tarafından
Demetrius White what make and model TV? What capacitors did you change? why? what are the symptoms that your TV has?
tarafından
Yorum Ekle
My Samsung TV ln46b750u1fxva takes a while to power up the light blinks and then comes back on
Puan 0
Yorum Ekle
If you have replace the caps on the main ps board, then you may need to replace a cap on the controller board…and possibly a chip. For me, it turned out that all I had to do was resolder the 47uf cap. I think over time the joints got “cold” and increase the ESR of the cap. While I bought a kit with the chip and caps, I did not have to use them…just resolder.
Find the MP2363 8-pin chip on the controller board…the cap is next to it.
Puan 0
Yorum Ekle
Yanıtını ekle
Bobby sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 3,955
